Home > Piping > Reducers >
ASME B-16.9 Butt Welded Eccentric Reducers
Butt welded eccentric reducers
Related type: Eccentric Reducers
Nominal DiameterLarge DiameterSmall DiameterRunThickness
ininininin
insert!3/4 x 3/81.050.6801.500.113
insert!3/4 x 1/21.050.8401.500.113
insert!1 x 3/41.3151.052.000.113
insert!1 x 1/21.3150.8402.000.113
insert!1 1/4 x 11.661.3152.000.140
insert!1 1/4 x 3/41.661.052.000.140
insert!1 1/4 x 1/21.660.8402.000.140
insert!1 1/2 x 1 1/41.901.662.500.145
insert!1 1/2 x 11.901.3152.500.145
insert!1 1/2 x 3/41.901.052.500.145
insert!1 1/2 x 1/21.900.8402.500.145
insert!2 x 1 1/22.3751.903.000.154
insert!2 x 1 1/42.3751.663.000.154
insert!2 x 12.3751.3153.000.154
insert!2 x 3/42.3751.053.000.154
insert!2 1/2 x 22.8752.3753.500.203
insert!2 1/2 x 1 1/22.8751.903.500.203
insert!2 1/2 x 1 1/42.8751.663.500.203
insert!2 1/2 x 12.8751.3153.500.203
insert!3 x 2 1/23.502.8753.500.216
insert!3 x 23.502.3753.500.216
insert!3 x 1 1/23.501.903.500.216
insert!3 x 1 1/43.501.663.500.216
insert!3 1/2 x 34.003.504.000.226
insert!3 1/2 x 2 1/24.002.8754.000.226
insert!3 1/2 x 24.002.3754.000.226
insert!3 1/2 x 1 1/24.001.904.000.226
insert!3 1/2 x 1 1/44.001.664.000.226
insert!4 x 3 1/24.504.004.000.237
insert!4 x 34.503.504.000.237
insert!4 x 2 1/24.502.8754.000.237
insert!4 x 24.502.3754.000.237
insert!4 x 1 1/24.501.904.000.237
insert!5 x 45.5634.505.000.258
insert!5 x 3 1/25.5634.005.000.258
insert!5 x 35.5633.505.000.258
insert!5 x 2 1/25.5632.8755.000.258
insert!5 x 25.5632.3755.000.258
insert!6 x 56.6255.5635.500.280
insert!6 x 46.6254.505.500.280
insert!6 x 3 1/26.6254.005.500.280
insert!6 x 36.6253.505.500.280
insert!6 x 2 1/26.6252.8755.500.280
insert!8 x 68.6256.6256.000.322
insert!8 x 58.6255.5636.000.322
insert!8 x 48.6254.506.000.322
insert!8 x 3 1/28.6254.006.000.322
insert!10 x 810.758.6257.000.365
insert!10 x 610.756.6257.000.365
insert!10 x 510.755.5637.000.365
insert!10 x 410.754.507.000.365
insert!12 x 1012.7510.758.000.375
insert!12 x 812.758.6258.000.375
insert!12 x 612.756.6258.000.375
insert!12 x 512.755.5638.000.375
insert!14 x 1214.0012.7513.000.375
insert!14 x 1014.0010.7513.000.375
insert!14 x 814.008.62513.000.375
insert!14 x 614.006.62513.000.375
insert!16 x 1416.0014.0014.000.375
insert!16 x 1216.0012.7514.000.375
insert!16 x 1016.0010.7514.000.375
insert!16 x 816.008.62514.000.375
insert!18 x 1618.0016.0015.000.375
insert!18 x 1418.0014.0015.000.375
insert!18 x 1218.0012.7515.000.375
insert!18 x 1018.0010.7515.000.375
insert!20 x 1820.0018.0020.000.375
insert!20 x 1620.0016.0020.000.375
insert!20 x 1420.0014.0020.000.375
insert!20 x 1220.0012.7520.000.375
insert!22 x 2022.0020.0020.000.375
insert!22 x 1822.0018.0020.000.375
insert!22 x 1622.0016.0020.000.375
insert!22 x 1422.0014.0020.000.375
insert!24 x 2224.0022.0020.000.375
insert!24 x 2024.0020.0020.000.375
insert!24 x 1824.0018.0020.000.375
insert!24 x 1624.0016.0020.000.375
insert!26 x 2426.0024.0024.000.375
insert!26 x 2226.0022.0024.000.375
insert!26 x 2026.0020.0024.000.375
insert!26 x 1826.0018.0024.000.375
insert!28 x 2628.0026.0024.000.375
insert!28 x 2428.0024.0024.000.375
insert!28 x 2228.0022.0024.000.375
insert!28 x 2028.0020.0024.000.375
insert!28 x 1828.0018.0024.000.375
insert!30 x 2830.0028.0024.000.375
insert!30 x 2630.0026.0024.000.375
insert!30 x 2430.0024.0024.000.375
insert!30 x 2230.0022.0024.000.375
insert!30 x 2030.0020.0024.000.375
insert!32 x 3032.0030.0024.000.375
insert!32 x 2832.0028.0024.000.375
insert!32 x 2632.0026.0024.000.375
insert!32 x 2432.0024.0024.000.375
insert!34 x 3234.0032.0024.000.375
insert!34 x 3034.0030.0024.000.375
insert!34 x 2834.0028.0024.000.375
insert!34 x 2634.0026.0024.000.375
insert!34 x 2434.0024.0024.000.375
insert!36 x 3436.0034.0024.000.375
insert!36 x 3236.0032.0024.000.375
insert!36 x 3036.0030.0024.000.375
insert!36 x 2636.0026.0024.000.375
insert!36 x 2436.0024.0024.000.375
insert!38 x 3638.0036.0024.000.375
insert!38 x 3438.0034.0024.000.375
insert!38 x 3238.0032.0024.000.375
insert!38 x 3038.0030.0024.000.375
insert!38 x 2838.0028.0024.000.375
insert!38 x 2638.0026.0024.000.375
insert!40 x 3840.0038.0024.000.375
insert!40 x 3640.0036.0024.000.375
insert!40 x 3440.0034.0024.000.375
insert!40 x 3240.0032.0024.000.375
insert!40 x 3040.0030.0024.000.375
insert!42 x 4042.0040.0024.000.375
insert!42 x 3842.0038.0024.000.375
insert!42 x 3642.0036.0024.000.375
insert!42 x 3442.0034.0024.000.375
insert!42 x 3242.0032.0024.000.375
insert!42 x 3042.0030.0024.000.375
insert!44 x 4244.0042.0024.000.375
insert!44 x 4044.0040.0024.000.375
insert!44 x 3844.0038.0024.000.375
insert!44 x 3644.0036.0024.000.375
insert!46 x 4446.0044.0028.000.375
insert!46 x 4246.0042.0028.000.375
insert!46 x 4046.0040.0028.000.375
insert!46 x 3846.0038.0028.000.375
insert!48 x 4648.0046.0028.000.375
insert!48 x 4448.0044.0028.000.375
insert!48 x 4248.0042.0028.000.375
insert!48 x 4048.0040.0028.000.375
custom!
ininininin
Note! Outside diameters and dimensions are correct for all schedules. Thickness are based on standard schedules. Use custom insert at the end of the table to insert custom components with other schedules.
The Engineering ToolBox Sketchup Edition provides a FREE 3D layout and design tool for techical installations as a plugin to the amazing Google Sketchup 3D modeling application.
Download the FREE Google Sketchup and the FREE plugin from this page to start running.
To limit the complexity and size of the models - details like holes in flanges, rounded corners on items like beams and similar - are omitted. Main dimensions of items are correct and details can be added by modifying the components after insertion.
Tip! If you navigate away from this menu through search results or adverts - use "Alt + Left Arrow" to go back one or more pages.
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 8 17
