Sign in!
Home > Structural Sections > Tee Sections >
BS 4 - Tee Sections
BS 4 part 1: 1993 Tee sections cut from Joists
bs 4 tee sections
DesignationDepthWidthThickness WebThickness FlangeRoot RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!203 x 127 x 41127203.210.219.919.652.3414641140194112
insert!114 x 127 x 19127114.37.612.812.423.718.631513510523.6
insert!152 x 102 x 26101.6152.48.916.515.533.326.120140898.953.5
insert!127 x 76 x 1976.212710.413.213.523.718.692.118952.529.8
insert!114 x 63.5 x 1563.5114.310.211.59.918.714.751.312134.121.2
insert!114 x 63 x 1463.5114.37.411.49.917.113.440.111830.320.6
insert!76 x 64 x 863.576.25.69.69.410.58.2729.330.420.78.0
insert!114 x 57 x 1457.15114.39.510.714.217.213.535.611226.919.6
insert!102 x 51 x 1250.8101.69.510.311.114.711.524.3772015.2
insert!44 x 51 x 450.844.54.36.16.94.753.7310.53.97.81.8
insert!89 x 45 x 1044.4588.99.59.911.112.49.7615.850.614.111.4
insert!76 x 38 x 838.176.28.98.49.49.579.519.230.59.47.6
insert!76 x 38 x 738.176.25.18.49.48.126.38625.97.46.8
custom!
Note that internal profiles with root radius, tapered flanges are not drawn. External dimensions are correct.
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 21
