Home  > Geometric Figures  >
Home  > Stairs and Ladders  >
Home  > Function Curves  >
Bezier Curve - in Equal Segments
A 4 points Bezier Curve split in a custum no. of segments with equal lengths. This tool can be useful when constructing walkable U- and L-shaped stairs
bezier curve with equal length segments
A four points Bezier curve can be expressed with the equation:
P(i) = P0 (1-i)3 + P1 3 i (1-i)2 + P2 3 i2 (1-t) + P3 i3
where the interval - i - runs from 0 to 1
Add coordinates of control points, no. of intervals and no. of segments - - and insert a segmented Bezier curve to your model. In addition to line segments small lines are added to indicate the angle between the segments. These lines can used to construct steps in a stair as indicated in the example bellow.
Note! - due to the nature of the Bezier equation the length of the segments will not be exactly equal. In general: smaller intervals increases accuracy.
This Bezier curve with equal segments don't work on Windows computers. The normal Bezier curve may be helpful.
red green blue
P0 - start point P0
Switch
P1
P1 - control point
P2 - control point P2
Switch
P3
P3 - end point
Insert Bezier Curve from the Points above!
Control Points from two Selected Lines?
Check here!
i - interval (0 - 1) (in the Bez. eq.)
no. of segments (split the Bez. curve)
Calculated Segments
Length
Color
Offset
Example - Construction of a L-shaped stair
Note that there are limits to the steps rise and run for a stair to be walkable. Check other stairs for more information. In addition - for a step to be walkable - the steps rise and run should be more or less constant in the "natural path" of the stair.
The "natural path" differ with persons and for persons over time - but a good aproximation to the "natural path" is the Bezier curve. This tool inserts a Bezier curve in what you define as the "natural path" - and split the curve in aprox. equal length segments. These segments can be used for the further construction of the stair.
Procedure
  • draw the footprint of the staircase
    footprint staircase
  • draw the control lines for the Bezier curve
    control lines bezier stair
  • measure the coordinates of the control lines and add them to the inputs above - use the "Get control points.." feature above, or from the dialog box, or use the "Tools > Text" feature in Sketchup - as used in the example above.
  • adjust the interval parameter if required (lower value - in general higher accuracy)
  • set the numbers of steps
  • insert the Bezier curve!
    bezier curve stair
  • repeat - change the control points until you find the "natural path" you believe is the best for the stair
  • extend the small lines between the segments until they touch the walls of the staircase
    steps
  • use the push/pull tool to "lift" the areas representing the steps to their exact levels. Tip! - insert a stair with the right height and the right number of steps as a reference for the push/pull tool
  • customize the stair and the steps - modify step noses, details ...
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
