Sign in!
Home > Piping > Pipes and Tubes >
Bended Pipe or Tube - Customized Angles and Dimensions
Add bend or elbows with custom dimensions
bend elbow customized
More segments makes smoother curves.
outside diameter
wall thickness
radius
angle
number of segments
Insert!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 20
