Home
Structural and Bar Sections
Tee Sections
Bar Size Tees
Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Sx | Section of Modulus - Sy | |
in | in | in | in | in | in**2 | lb/ft | in**4 | in**4 | in**3 | in**3 | ||
insert! | 1 x 1 x 1/8 | 1 | 1 | 0.125 | 0.125 | 0.85 | ||||||
insert! | 1 1/4 x 1 1/4 x 1/8 | 1.250 | 1.250 | 0.125 | 0.125 | 1.09 | ||||||
insert! | 1 1/4 x 1 1/4 x 3/16 | 1.250 | 1.250 | 0.1875 | 0.1875 | 1.55 | ||||||
insert! | 1 1/2 x 1 1/2 x 3/16 | 1.5 | 1.5 | 0.1875 | 0.1875 | 1.9 | ||||||
insert! | 1 1/2 x 1 1/2 x 1/4 | 1.5 | 1.5 | 0.250 | 0.250 | 2.43 | ||||||
insert! | 1 3/4 x 1 3/4 x 3/16 | 1.750 | 1.750 | 0.1875 | 0.1875 | 2.16 | ||||||
insert! | 2 x 2 x 1/4 | 2 | 2 | 0.250 | 0.250 | 3.62 | ||||||
insert! | 2 1/2 x 2 1/2 x 1/4 | 2.5 | 2.5 | 0.250 | 0.250 | 4.6 | ||||||
custom! |
Note that internal profiles with root radius, tapered flanges are not drawn. External dimensions are correct.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
