Sign in!
Home > Structural Sections > Flange Beams and Columns >
W - American Standard Steel Wide Flange Beams
ASTM A6 - Dimensions and static parameters of American steel wide flange beams - Imperial Units
astm a6 american wide flange steel beam
DesignationDepthWidthThickness WebThickness FlangeSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
ininininin**2lb/ftin**4in**4in**3in**3
insert!W 27 x 17827.8114.0850.7251.19052.3178699055550278.8
insert!W 27 x 16127.5914.0200.6601.08047.4161628049745570.9
insert!W 27 x 14627.3813.9650.6050.97542.9146563044341163.5
insert!W 27 x 11427.2910.0700.5700.93033.5114409015929931.5
insert!W 27 x 10227.0910.0150.5150.83030.0102362013926727.8
insert!W 27 x 9426.929.9900.4900.74527.794327012424324.8
insert!W 27 x 8426.719.9600.4600.64024.884285010621321.2
insert!W 24 x 16225.0012.9550.7051.22047.7162517044341468.4
insert!W 24 x 14624.7412.9000.6501.09043.0146458039137160.5
insert!W 24 x 13124.4812.8550.6050.96038.5131402034032953.0
insert!W 24 x 11724.2612.8000.5500.85034.4117354029729146.5
insert!W 24 x 10424.0612.7500.5000.75030.6104310025925840.7
insert!W 24 x 9424.319.0650.5150.87527.794270010922224.0
insert!W 24 x 8424.109.0200.4700.77024.784237094.419620.9
insert!W 24 x 7623.928.9900.4400.68022.476210082.517618.4
insert!W 24 x 6823.738.9650.4150.58520.168183070.415415.7
insert!W 24 x 6223.747.0400.4300.59018.262155034.51319.8
insert!W 24 x 5523.577.0050.3950.50516.255135029.11148.3
insert!W 21 x 14722.0612.5100.7201.15043.2147363037632960.1
insert!W 21 x 13221.8314.4400.6501.03538.8132322033329553.5
insert!W 21 x 12221.6812.3900.6000.96035.9122296030527349.2
insert!W 21 x 11121.5112.3400.5500.87532.7111267027424944.5
insert!W 21 x 10121.3612.2900.5000.80029.8101242024822740.3
insert!W 21 x 9321.628.4200.5800.93027.393207092.919222.1
insert!W 21 x 8321.438.3550.5150.83524.383183081.417119.5
insert!W 21 x 7321.248.2950.4550.74021.573160070.615117.0
insert!W 21 x 6821.138.2700.4300.68520.068148064.714015.7
insert!W 21 x 6220.998.2400.4000.61518.362133057.512713.8
insert!W 21 x 5721.066.5550.4050.65016.757117030.61119.35
insert!W 21 x 5020.836.5300.3800.53514.75098424.494.57.64
insert!W 21 x 4420.666.5000.3500.45013.04484320.781.66.36
insert!W 18 x 11918.9711.2650.6551.06035.1119219025323144.9
insert!W 18 x 10618.7311.2000.5900.94031.1106191022020439.4
insert!W 18 x 9718.5911.1450.5350.87028.597175020118836.1
insert!W 18 x 8618.3911.0900.4800.77025.386153017516631.6
insert!W 18 x 7618.2111.0350.4250.68022.376133015214627.6
insert!W 18 x 7118.477.6350.4950.81020.871117060.312715.8
insert!W 18 x 6518.357.5900.4500.75019.165107054.811714.4
insert!W 18 x 6018.247.5550.4150.69517.66098450.110813.3
insert!W 18 x 5518.117.5300.3900.63016.25589044.998.311.9
insert!W 18 x 5017.997.4950.3550.57014.75080040.188.910.7
insert!W 18 x 4618.096.0600.3600.60513.54671222.578.87.43
insert!W 18 x 4017.906.0150.3150.52511.84061219.168.46.35
insert!W 18 x 3517.706.0000.3000.42510.33551015.357.65.12
insert!W 16 x 10016.9710.4250.5850.98529.4100149018617535.7
insert!W 16 x 8916.7510.3650.5250.87526.289130016315531.4
insert!W 16 x 7716.5210.2950.4550.76022.677111013813426.9
insert!W 16 x 6716.3310.2350.3950.66519.76795411911723.2
insert!W 16 x 5716.437.1200.4300.71516.85775843.192.212.1
insert!W 16 x 5016.267.0700.3800.63014.75065937.281.010.5
insert!W 16 x 4516.137.0350.3450.56513.34558632.872.79.34
insert!W 16 x 4016.016.9950.3050.50511.84051828.964.78.25
insert!W 16 x 3615.866.9850.2950.43010.63644824.556.57.00
insert!W 16 x 3115.885.5250.2750.4409.123137512.447.24.49
insert!W 16 x 2615.695.5000.2500.3457.68263019.5938.43.49
insert!W 14 x 73022.4217.8903.0704.9102157301430047201280527
insert!W 14 x 66521.6417.6502.8304.5201966651240041701150472
insert!W 14 x 60520.9217.4152.5954.1601786051080036801040423
insert!W 14 x 55020.2417.2002.3803.82016255094303250931378
insert!W 14 x 50019.6017.0102.1903.50014750082102880838339
insert!W 14 x 45519.0216.8352.0153.21013445571902560756304
insert!W 14 x 42618.6716.6951.8753.03512542666002360707283
insert!W 14 x 39818.2916.5901.7702.84511739860002170656262
insert!W 14 x 37017.9216.4751.6552.66010937054401990607241
insert!W 14 x 34217.5716.3601.5402.47010134249001810559221
insert!W 14 x 31117.1216.2301.4102.26091.431143301610506199
insert!W 14 x 28316.7416.1101.2902.07083.328338401440459179
insert!W 14 x 25716.3815.9951.1751.89075.625734001290415161
insert!W 14 x 23316.0415.8901.0701.72068.523330101150375145
insert!W 14 x 21115.7215.8000.9801.56062.021126601030338130
insert!W 14 x 19315.4815.7100.8901.44056.81932400931310119
insert!W 14 x 17615.2215.6500.8301.31051.81762140838281107
insert!W 14 x 15914.9815.5650.7451.19046.7159190074825496.2
insert!W 14 x 14514.7815.5000.6801.09042.7145171067723287.3
insert!W 14 x 13214.6614.7250.6451.03038.8132153054820974.5
insert!W 14 x 12014.4814.6700.5900.94035.3120138049519067.5
insert!W 14 x 10914.3214.6050.5250.86032.0109124044717361.2
insert!W 14 x 9914.1614.5650.4850.78029.199111040215755.2
insert!W 14 x 9014.0214.5200.4400.71026.59099936214349.9
insert!W 14 x 8214.3110.1300.5100.85524.18288214812329.3
insert!W 14 x 7414.1710.0700.4500.78521.87479613411226.6
insert!W 14 x 6814.0410.0350.4150.72020.06872312110324.2
insert!W 14 x 6113.899.9950.3750.64517.96164010792.221.5
insert!W 14 x 5313.928.0600.3700.66015.65354157.777.814.3
insert!W 14 x 4813.798.0300.3400.59514.14848551.470.312.8
insert!W 14 x 4313.667.9950.3050.53012.64342845.262.711.3
insert!W 14 x 3814.106.7700.3100.51511.23838526.754.67.88
insert!W 14 x 3413.986.7450.2850.45510.03434026.348.66.91
insert!W 14 x 3013.846.7300.2700.3858.853029119.642.05.82
insert!W 14 x 2613.915.0250.2550.4207.69262458.9135.33.54
insert!W 14 x 2213.745.0000.2300.3356.49221997.0029.02.80
insert!W 12 x 33616.8213.3851.7752.95598.833640601190483177
insert!W 12 x 30516.3213.2351.6252.70589.630535501050435159
insert!W 12 x 27915.8513.1401.5302.47081.92793110937393143
insert!W 12 x 25215.4113.0051.3952.25074.12522720828353127
insert!W 12 x 23015.0512.8951.2852.07067.72302420742321115
insert!W 12 x 21014.7112.7901.1801.90061.82102140664292104
insert!W 12 x 19014.3812.6701.0601.73555.8190189058926393.0
insert!W 12 x 17014.0312.5700.9601.56050.0170165051723582.3
insert!W 12 x 15213.7112.4800.8701.40044.7152143045420972.8
insert!W 12 x 13613.4112.4000.7901.25039.9136124039818664.2
insert!W 12 x 12013.1212.3200.7101.10535.3120107034516356.0
insert!W 12 x 10612.8912.2200.6100.99031.210693330114549.3
insert!W 12 x 9612.7112.1600.5500.90028.29683327013144.4
insert!W 12 x 8712.5312.1250.5150.81025.68774024111839.7
insert!W 12 x 7912.3812.0800.4700.73523.27966221610735.8
insert!W 12 x 7212.2512.0400.4300.67021.17259719597.432.4
insert!W 12 x 6512.1212.0000.3900.60519.16553317487.929.1
insert!W 12 x 5812.1910.0100.3600.64017.05847510778.021.4
insert!W 12 x 5312.069.9950.3450.57515.65342595.870.619.2
insert!W 12 x 5012.198.0800.3700.64014.75039456.364.713.9
insert!W 12 x 4512.068.0450.3350.57513.24535050.058.112.4
insert!W 12 x 4011.948.0050.2950.51511.84031044.151.911.0
insert!W 12 x 3512.506.5600.3000.52010.33528524.545.67.47
insert!W 12 x 3012.346.5200.2600.4408.793023820.338.66.24
insert!W 12 x 2612.226.4900.2300.3807.652620417.333.45.34
insert!W 12 x 2212.314.0300.2600.4256.48221564.6625.42.31
insert!W 12 x 1912.164.0050.2350.3505.57191303.7621.31.88
insert!W 12 x 1611.993.9900.2200.2654.71161032.8217.11.41
insert!W 12 x 1411.913.9700.2000.2254.161488.62.3614.91.19
insert!W 10 x 11211.3610.4150.7551.25032.911271623612645.3
insert!W 10 x 10011.1010.3400.6801.12029.410062320711240.0
insert!W 10 x 8810.8410.2650.6050.99025.98853417998.534.8
insert!W 10 x 7710.6010.1900.5300.87022.97745515485.930.1
insert!W 10 x 6810.4010.1300.4700.77020.06839413475.726.4
insert!W 10 x 6010.2210.0800.4200.68017.66034111666.723.0
insert!W 10 x 5410.0910.0300.3700.61515.85430310360.020.6
insert!W 10 x 499.9810.0000.3400.56014.44927293.454.618.7
insert!W 10 x 4510.108.0200.3500.62013.34524853.449.113.3
insert!W 10 x 399.927.9850.3150.53011.53920945.042.111.3
insert!W 10 x 339.737.9600.2900.4359.713317036.635.09.20
insert!W 10 x 3010.475.8100.3000.5108.843017016.732.45.75
insert!W 10 x 2610.335.7700.2600.4407.612614414.127.94.89
insert!W 10 x 2210.175.7500.2400.3606.492211811.423.23.97
insert!W 10 x 1910.244.0200.2500.3955.621996.34.2918.82.14
insert!W 10 x 1710.114.0100.2400.3304.991781.93.5616.21.78
insert!W 10 x 159.994.0000.2300.2704.411568.92.8913.81.45
insert!W 10 x 129.873.9600.1900.2103.541253.82.1810.91.10
insert!W 8 x 679.008.2800.5700.93519.76727288.660.421.4
insert!W 8 x 588.758.2200.5100.81017.15822875.152.018.3
insert!W 8 x 488.508.1100.4000.68514.14818460.943.315.0
insert!W 8 x 408.258.0700.3600.56011.74014649.135.512.2
insert!W 8 x 358.128.0200.3100.49510.33512742.631.210.6
insert!W 8 x 318.007.9950.2850.4359.133111037.127.59.27
insert!W 8 x 288.066.5350.2850.4658.252898.021.724.36.63
insert!W 8 x 247.936.4950.2450.4007.082482.818.320.95.63
insert!W 8 x 218.285.2700.2500.4006.162175.39.7718.23.71
insert!W 8 x 188.145.2500.2300.3305.261861.97.9715.23.04
insert!W 8 x 158.114.0150.2450.3154.441548.03.4111.81.70
insert!W 8 x 137.994.0000.2300.2553.841339.62.739.911.37
insert!W 8 x 107.893.9400.1700.2052.961030.82.097.811.06
insert!W 6 x 256.386.0800.3200.4557.342553.417.1016.75.61
insert!W 6 x 206.206.0200.2600.3655.872041.413.3013.44.41
insert!W 6 x 166.284.0300.2600.4054.741632.14.4310.22.20
insert!W 6 x 155.995.9900.2300.2604.431529.19.329.723.11
insert!W 6 x 126.034.0000.2300.2803.551222.12.997.311.50
insert!W 6 x 95.903.9400.1700.2152.68916.42.195.561.11
insert!W 5 x 195.155.0300.2700.4305.541926.29.1310.23.63
insert!W 5 x 165.015.0000.2400.3604.681621.37.518.513.00
insert!W 4 x 134.164.0600.2800.3453.831311.33.865.461.90
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 13
