Sign in!
Home > Piping > Pipes and Tubes >
Aluminum and Aluminum-Alloy Seamless Pipe and Seamless Extruded Tube
Standard Specification for Aluminum and Aluminum-Alloy Seamless Pipe and Seamless Extruded Tube
aluminium seamless extruded pipes tubes
Nominal DiameterScheduleAlternative IdentificationOutside DiameterInside DiameterWall ThicknessWeightInside AreaMoment of InertiaSection Modulus
ininininlb/ftin**2in**4in**3
insert!1/840STD0.4050.2690.0680.090.060.00110.0053
insert!1/880XS0.4050.2150.0950.110.040.00120.0060
insert!1/440STD0.5400.3640.0880.150.100.00330.0123
insert!1/480XS0.5400.3020.1190.190.070.00380.0139
insert!3/840STD0.6750.4930.0910.200.190.00730.0216
insert!3/880XS0.6750.4230.1260.260.140.00860.0255
insert!1/240STD0.8400.6220.1090.290.300.01710.0407
insert!1/280XS0.8400.5460.1470.380.230.02010.0478
insert!3/4101.0500.8840.0830.300.610.02970.0566
insert!3/440STD1.0500.8240.1130.390.530.03700.0705
insert!3/480XS1.0500.7420.1540.510.430.04480.0853
insert!151.3151.1850.0650.301.100.5000.0760
insert!1101.3151.0970.1090.490.950.07570.1151
insert!140STD1.3151.0490.1330.580.860.08730.1328
insert!180XS1.3150.9570.1790.750.720.10560.1606
insert!1 1/451.6601.5300.0650.381.840.10370.1250
insert!1 1/4101.6601.4420.1090.631.630.16050.1934
insert!1 1/440STD1.6601.3800.1400.791.500.19470.2346
insert!1 1/480XS1.6601.2780.1911.041.280.24180.2913
insert!1 1/251.9001.7700.0650.442.460.15790.1662
insert!1 1/2101.9001.6820.1090.722.220.24680.2598
insert!1 1/240STD1.9001.6100.1450.942.040.30990.3262
insert!1 1/280XS1.9001.5000.2001.261.770.39120.4118
insert!252.3752.2450.0650.563.960.31490.2652
insert!2102.3752.1570.1090.913.650.49920.4204
insert!240STD2.3752.0670.1541.263.360.66570.5606
insert!280XS2.3751.9390.2181.742.950.86790.7309
insert!2 1/252.8752.7090.0830.865.760.71000.4939
insert!2 1/2102.8752.6350.1201.225.450.98730.6868
insert!2 1/240STD2.8752.4690.2032.004.791.5301.064
insert!2 1/280XS2.8752.3230.2762.654.241.9241.339
insert!353.5003.3340.0831.058.731.3010.7435
insert!3103.5003.2600.1201.508.351.8221.041
insert!340STD3.5003.0680.2162.627.393.0171.724
insert!380XS3.5002.9000.3003.556.613.8942.225
insert!3 1/254.0003.8340.0831.2011.551.9600.9799
insert!3 1/2104.0003.7600.1201.7211.102.7551.378
insert!3 1/240STD4.0003.5480.2263.159.894.7882.394
insert!3 1/280XS4.0003.3640.3184.338.896.2813.140
insert!454.5004.3340.0831.3514.752.8101.249
insert!4104.5004.2600.1201.9414.253.9631.761
insert!440STD4.5004.0260.2373.7312.737.2323.214
insert!480XS4.5003.8260.3375.1811.509.6114.272
insert!540STD5.5635.0470.2585.0620.0115.165.451
insert!580XS5.5634.8130.3757.1918.1920.677.432
insert!656.6256.4070.1092.6232.2411.853.576
insert!640STD6.6256.0650.2806.5628.8928.148.496
insert!680XS6.6255.7610.4329.8826.0740.4912.22
insert!8308.6258.0710.2778.5451.1663.3514.69
insert!840STD8.6257.9810.3229.8850.0372.4916.81
insert!880XS8.6257.6250.50015.0145.66105.724.51
insert!1010.75010.1920.27910.7981.59125.923.42
insert!103010.75010.1360.30711.8480.69137.425.57
insert!1040STD10.75010.0200.36514.0078.86160.729.90
insert!1060XS10.7509.7500.50018.9374.66211.939.43
insert!123012.75012.0900.33015.14114.80248.538.97
insert!1240STD12.75011.9380.40618.52111.94300.047.10
insert!1260XS12.75011.7500.50022.63108.43361.556.71
custom!
Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
