Sign in!
Home > Piping > Flanges >
UNI EN 1092-1 Plane Flanges PN6
From EN 1092-1 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories - PN designated
plane flanges pn 6
insert! DN15 Plane Flange PN6 UNI EN 1092-1
insert! DN20 Plane Flange PN6 UNI EN 1092-1
insert! DN25 Plane Flange PN6 UNI EN 1092-1
insert! DN32 Plane Flange PN6 UNI EN 1092-1
insert! DN40 Plane Flange PN6 UNI EN 1092-1
insert! DN50 Plane Flange PN6 UNI EN 1092-1
insert! DN65 Plane Flange PN6 UNI EN 1092-1
insert! DN80 Plane Flange PN6 UNI EN 1092-1
insert! DN100 Plane Flange PN6 UNI EN 1092-1
insert! DN125 Plane Flange PN6 UNI EN 1092-1
insert! DN150 Plane Flange PN6 UNI EN 1092-1
insert! DN200 Plane Flange PN6 UNI EN 1092-1
insert! DN250 Plane Flange PN6 UNI EN 1092-1
insert! DN300 Plane Flange PN6 UNI EN 1092-1
insert! DN350 Plane Flange PN6 UNI EN 1092-1
insert! DN400 Plane Flange PN6 UNI EN 1092-1
insert! DN450 Plane Flange PN6 UNI EN 1092-1
insert! DN500 Plane Flange PN6 UNI EN 1092-1
insert! DN600 Plane Flange PN6 UNI EN 1092-1
Thanks to Paolo Pizzorni for providing these models.
If there the "insert!" don't work on your Mac- click the right link in a browser window outside Sketchup - and download the component to your computer.
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 21
