Sign in!
Home > Structural Sections > Circular Hollow Sections >
UK CHS - Circular Hollow Sections
UK Circular Hollow Sections
UK CHS circular hollow section
DesignationOutside DiameterWall ThicknessWeight
mmmmkg/m
insert!CHS 508 x 12.550812.5153
insert!CHS 508 x 1050810
insert!CHS 457 x 4045740411
insert!CHS 457 x 3245732335
insert!CHS 457 x 2545725266
insert!CHS 457 x 2045720216
insert!CHS 457 x 1645716174
insert!CHS 457 x 12.545712.5137
insert!CHS 457 x 1045710110
insert!CHS 406.4 x 32406.432295
insert!CHS 406.4 x 25406.425235
insert!CHS 406 x 20406.420191
insert!CHS 406.4 x 16406.416154
insert!CHS 406.4 x 12.5406.412.5121
insert!CHS 406.4 x 10406.41097.8
insert!CHS 355.6 x 25355.625204
insert!CHS 355.6 x 20355.620166
insert!CHS 355.6 x 16355.616134
insert!CHS 355.6 x 12.5355.612.5106
insert!CHS 355.6 x 10355.61085.2
insert!CHS 355.6 x 8355.6868.6
insert!CHS 323..9 x 25323.925184
insert!CHS 323.9 x 20323.920150
insert!CHS 323.9 x 16323.916121
insert!CHS 323.9 x 12.5323.912.596
insert!CHS 323.9 x 10323.91077.4
insert!CHS 323.9 x 8323.9862.3
insert!CHS 323.9 x 6.3323.96.349.3
insert!CHS 283 x 102381064.9
insert!CHS 273 x 2527325153
insert!CHS 273 x 2027320125
insert!CHS 273 x 1627316101
insert!CHS 273 x 12.527312.580.3
insert!CHS 273 x 102731064.9
insert!CHS 273 x 8273852.3
insert!CHS 273 x 6.32736.341.4
insert!CHS 244.5 x 20244.520111
insert!CHS 244.5 x 16244.51690.2
insert!CHS 244.5 x 12.5244.512.571.5
insert!CHS 244.5 x 10244.51057.8
insert!CHS 244.5 x 8244.5846.7
insert!CHS 244.5 x 6.3244.56.337
insert!CHS 219.1 x 20219.12098.2
insert!CHS 219.1 x 16219.11680.1
insert!CHS 219.1 x 12.5219.112.563.7
insert!CHS 219.1 x 10219.11051.6
insert!CHS 219.1 x 8219.1841.6
insert!CHS 219.1 x 6.3219.16.333.1
insert!CHS 219.1 x 5219.1526.4
insert!CHS 193.7 x 16193.71670.1
insert!CHS 193.7 x 12.5193.712.555.9
insert!CHS 193.7 x 10193.71045.3
insert!CHS 193.7 x 8193.7836.6
insert!CHS 193.7 x 6.3193.76.329.1
insert!CHS 193.7 x 5.4193.75.425.1
insert!CHS 193.7 x 5193.7523.3
insert!CHS 168.3 x 10168.31039
insert!CHS 168.3 x 8168.3831.6
insert!CHS 168.3 x 6.3168.36.325.2
insert!CHS 168.3 x 5168.3520.1
insert!CHS 139.7 x 10139.71032
insert!CHS 139.7 x 8139.7826
insert!CHS 139.7 x 6.3139.76.320.7
insert!CHS 139.7 x 5139.7516.6
insert!CHS 114.3 x 6.3114.36.316.8
insert!CHS 114.3 x 5114.3513.5
insert!CHS 114.3 x 3.6114.33.69.83
insert!CHS 88.9 x 588.9510.3
insert!CHS 88.9 x 488.948.38
insert!CHS 88.9 x 3.288.93.26.76
insert!CHS 76.1 x 576.158.77
insert!CHS 76.1 x 476.147.11
insert!CHS 76.1 x 3.276.13.25.75
insert!CHS 60.3 x 560.356.82
insert!CHS 60.3 x 460.345.55
insert!CHS 60.3 x 3.260.33.24.51
insert!CHS 48.3 x 548.355.34
insert!CHS 48.3 x 448.344.37
insert!CHS 48.3 x 3.248.33.23.56
insert!CHS 42.4 x 442.443.79
insert!CHS 42.4 x 3.242.43.23.09
insert!CHS 42.4 x 2.642.42.62.55
insert!CHS 33.7 x 433.742.93
insert!CHS 33.7 x 3.233.73.22.41
insert!CHS 33.7 x 2.633.72.61.99
insert!CHS 26.9 x 3.226.93.21.87
insert!CHS 21.3 x 3.2213.21.43
custom!
mmmmkg/m
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 21
