HVAC Circular Ducts - metric units
Add standard ducts to your Sketchup model by clicking "insert!
Customized ducts can be added by modifying the "custom!" row.
| Nominal Diameter | Outside Diameter | Wall Thickness | Inside Area | |
| mm | mm | mm | m**2 | |
| insert! | 60 | 63 | 1 | 0.003 |
| insert! | 80 | 80 | 1 | 0.005 |
| insert! | 100 | 100 | 1 | 0.008 |
| insert! | 125 | 125 | 1 | 0.012 |
| insert! | 160 | 160 | 1 | 0.020 |
| insert! | 200 | 200 | 1 | 0.031 |
| insert! | 250 | 250 | 1 | 0.049 |
| insert! | 315 | 315 | 1 | 0.078 |
| insert! | 400 | 400 | 1 | 0.126 |
| insert! | 500 | 500 | 1 | 0.196 |
| insert! | 630 | 630 | 1 | 0.312 |
| insert! | 800 | 800 | 1 | 0.502 |
| insert! | 1000 | 1000 | 1 | 0.785 |
| insert! | 1250 | 1250 | 1 | 1.227 |
| custom! | ||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 9 3
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
